Hey all!
I was using webget with the following formulas to pull lyrics from lrclib.
Gv(url) = https://lrclib.net/api/get?artist_name=$mi(artist)$&track_name=$mi(title)$
$wg(gv(url), json, .syncedLyrics)$
It was working beautifully, but then all of a sudden yesterday it was not.
My app did update to the latest version recently and I did update all permissions
Any ideas on what might be going on?
Thanks for the help!
MaxP
August 5, 2026, 8:39pm
2
It’s probably an issue with the latest version. Try installing an earlier one.
kwgt downloads# Latest stable: 3.82# Download: Google Play APK Build: 3.82b621115 Size: 37.82mb Uploaded: 2026-07-30T15:03:23Z
Variants# aosp: 3.82b619510aosp (No PRO required, ADS supported, no Google Services) huawei: 3.82b610514huawei (App Gallery...
I actually downloaded the app from April 3.82b610016 and still the same
Hi @Mfreund21 ,
AFAIK, retrieving data through $wg(…)$ need some time, even just a split second. And we have to wait for the response to be available, before processing it. That’s why we need a Flow to do those sequential tasks. It is the best practice.
Here’s my tutorial video on how to get the song info from LrcLib.net , it is applicable to KLWP, KWGT, and KLCK.
Preview
[Get Song Info from LrcLib.net]
Tutorial Video
Preset Download
How to Open in KLWP
Downloaded the preset file (the .klwp file) to your phone
Copy/move the downloaded preset file to the wallpapers folder, under the installation folder of the KLWP
Run the KLWP editor and load the copied/moved preset
I include a link to the tutorial video as well as a KLWP preset as an example.
Thank you for sending. I followed the steps and it’s still not working for me unfortunately. I also get a 404 error when trying to view your preset
Try to download the preset rather than opening it from Google Drive.
@Mfreund21 :
Would you like me to help you investigating your KWGT preset and troubleshooting it?
If so, you could message me to share this KWGT preset.
Screenshots for Step-by-step Guide
01. Global variables
lyrics: used as the container for the API response
toggle: used for running the Flow
02. Flow trigger: Formula
Formula : $gv(toggle)$
Trigger mode : When not 0 or empty
03. Flow action #1: Web Get
URL : $"https://lrclub.net/api/get?artist_name="+mi(artist)+"&track_name="+mi(title)$
Headers : X-User-Agent
Method : GET
04. Flow action #2: Set Global Var
Global : lyrics
Store mode : As text
05. Script for the Text element
Get the syncedLyrics value from the JSON data of the API response: $tc(json, gv(lyrics), ".syncedLyrics")$
Ok I’m getting closer. The lyrics are now pulling into the lyric global variable, but when I add the text element I get this error
Hi @Mfreund21 ,
That’s okay, it happens when the lyrics variable has not been filled with the data yet. You can see the same error message in my tutorial video. But once the variable has its value, that error would be gone.
TIPS
To avoid such error, set an initial value for the lyrics variable: enter a single space character (for example).
Got it to work. Thank you!
So I used the trigger as when the song changes. Is there a way to add a conditional in the flow to clear the lyrics global if lyrics are not found?
Currently if it does not find the lyrics the previous songs lyrics remain
Hi @Mfreund21 ,
Would you mind sharing the preset with me? I could help you adjusting it to your need.
Hi @Mfreund21 ,
Thank you for sharing the preset.
I have explored the preset and it seems like you created it with a nested Komponents. IMO this might be the cause of the issue, but I’ll look into it further to find anything solution to the issue you have with the lyrics retrieval.
Thank you! Yea I used komponents to make them easier to use between kwgt and klwp. I can remake it without them if that makes things work easier
This was working great and now just stopped working. I did a test run of the flow and am getting this error now.
Hi @Mfreund21 ,
It looks like the API reject the request and response.
Try to enable both of these:
ignore SSL Errors
Ignore HTTP Errors
And try to change the header, to either of these:
Hi @Mfreund21 ,
I have tried to add the lyrics into your KWGT preset but it seems that it cannot be done in a nested Komponents.
However, I just created a KWGT preset, it’s a simple Media Player. Hopefully it matches to your need and you could use it as you like.
Here’s my KWGT preset for Simple Media Player:
Preview
[Simple Media Player]
Preset Download
How to Use the KWGT Preset
Download the preset file (the .kwgt file) to your phone
Copy/move the downloaded preset file to the widgets folder, under the installation folder of the Kustom app
Add a new widget on homescreen, choose Kustom Widget and select your preferred size of the widget
Tap on the blank new widget on homescreen to open the KWGT editor, then load the copied/moved preset
Enjoy the widget!
dre007
August 11, 2026, 11:04am
20
Have the same problem, still on 3.79
