Widget • Simple Media Player v1.0.260809
Preview
Preset Download
How to Use the KWGT Preset
  1. Download the preset file (the .kwgt file) to your phone
  2. Copy/move the downloaded preset file to the widgets folder, under the installation folder of the Kustom app
  3. Add a new widget on homescreen, choose Kustom Widget and select your preferred size of the widget
  4. Tap on the blank new widget on homescreen to open the KWGT editor, then load the copied/moved preset
Enjoy the widget!
