This is a Mini Player komponent that can be used/inserted in either one of these Kustom apps:
- KWGT a.k.a. Kustom Widget
- KLWP a.k.a. Kustom Live Wallpaper
- KLCK a.k.a. Kustom Lock Screen
Preview
Downloads
How to Use
In KWGT
- Download the Komponent file (
.kompfile) - Copy/move the downloaded file to your phone, into the
Komponentsfolder (under your Kustom installation folder) - Add a new blank widget on your homescreen
- Tap on the new blank widget to open the KWGT editor
- In the KWGT editor, insert a new element (the Komponent type), and select the Komponent you want to use (in this case, my Mini Player v1.0.261124 komponent)
- Et voilà
In KLWP and KLCK
Komponentsfolder (under your Kustom installation folder) - In the KLWP|KLCK editor, insert a new element (the Komponent type), and select the Komponent you want to use (in this case, my Mini Player v1.0.261124 komponent)
- Et voilà
Customisable Fonts
In komponent’s Global tab, there are 2 global variables (Font type) used by the komponent.
default: any regular typefacebold: any bold typeface
Tips
- The aspect ratio of the komponent is 2:1
- In KWGT, choose 2:1 aspect ratio for the widget size and it is best to resize the widget to more than 50% screen width
- It is recommended to use condensed typeface, such as: Roboto Condensed, Arial Narrow, etc.
