My communication in the General category.
Volmark:
How to rename a preset (or space)? Instead of Widget 32, to rename into something usable
Ace:
You will have to export the widget to give it a proper name and all the additional details.
Volmark:
Stll unclear how to rename preset. Have tried to rename the file kwgt but internally (Kustom panel) it still has the old name. When export it again the kwgt file saved with the old name. Also description. How to edit it?
Plz, help …
