Clock-block simple digital clock KWGT component
I wanted a clean simple clock. Made this from scratch with a bit of trial and error. Nothing copied - even the name (which seemed like an obvious choice) so there’s probably stuff out there that looks the same. The component is unlocked so you can tweak it and make it your own.
Tap zones:
TL: select font (select 4 fonts in Globals < Settings)
TC: hide/show background
TR: swap colours (edit 2 colours in Globals < Settings)
C: launch clock app (edit app in Items < Settings)
BL: show icons, open settings
BC: change corner roundness
BR: rotate time
Get it here: clock_block.komp - Google Drive
nice, looks amazing and provides the easy customization from home screen
Changes reset on phone/app restart so for more permanent changes go into settings (open widget in KWGT), tap the tap zones and hit the save button.
