The actual value should be 42.79 GB (see screenshot in the first comment).
I’ve been testing it and fine tuning it for two months, the issue is always there. The reset date (7th of the month) is correct, I also tried changing that but the number is still way lower than the actual value.
I see this issue is talked about here and on reddit, any ETA for a solution?
I understand. To my knowledge, KWGT begins storing data traffic information only upon first use, which might explain why its reading is lower than the system’s tracked data usage.
