Wpcolor not working
I’m using S25 Ultra and since one ui 8.5, wpcolor1 and wpcolor2 is stopped working.
Would love it to be solved. Thank you
On many newer phones, WP Color is no longer supported. I can’t say exactly which models are affected, but there have been a lot of reports from Samsung S series users running Android 16.
Because of that, I would recommend gradually switching to the system color engine and using formulas based on si(sysca1, …).
It’s not exactly the same as WP Color, but it works reliably across devices and still allows for very precise color adjustments and customization. In my experience, it’s currently the most compatible and future proof solution. I’ve actually stopped using WP Color myself ever since Android 16 was released and the first compatibility reports started coming in…
