(WIP) Poketch Digital Watch (Sound Effects w/ MacroDroid)
https://drive.google.com/drive/folders/1PXw88tlQOMNIZd-vnV2Vl08YIgZbNeGV?usp=sharing
Updated Poketch Digital Watch to include additional information such as:
-Weather
-Cellular Band
-Battery Percentage with Life Bar
-Interactive Rotom Sprite w/ Pokemon Cry (MacroDroid needed for Pokemon Cry) (Gen 4 version) when clicked (Added to fit the theme of Rotom inhabiting devices like with the Rotom Pokedex; was thinking of eventually making a Rotom Poketch Widget where the background is orange and the Pikachu sprite is replaced with Rotom)
All assets used are included in the download with the KWGT preset
Planned additions still WIP as I’m learning how to use KWGT (if anyone has pointers please share)
-Rounded Battery Life progress bar
-Celluar Strength Bars
-Wi-Fi status and strength bars
-Ringer status (on, vibrate, silent)
In MacroDroid create a macro using the following settings and selecting the “Rotom Cry” MP3
In KWGT add a “Launch Shortcut” Touch Action where you can then select the “Rotom Cry” Macro that you made in MacroDroid
-You can set the “Launch Shortcut” touch action on the widget as whole or a specific object; the preset has it set to activate when you click the Rotom sprite specifically but you can set it to the widget itself if you prefer
Close up of the widget
