Widgets look blown up and out of proportion
I have a widget that I used in my pixel 9 pro xl with the latest kwgt pro version. And the widget looks blown up and out of proportion and does not fit properly when I put it on my pixel 11 pro xl. Both of them are running Android 17. The top one is the one on my current phone and the second one is how it looks on my new phone. I have check all the strings and they are the same.
I already told you on Reddit check the size of the main root layer without opening other elements. Slowly reduce it until your widget reaches the optimal size.
It’s enough to create a widget on one launcher and then place it on another Kustom tries to auto‑increase the root layer size, and that’s why everything gets messed up.
Hi @Juan_Castro ,
Here is my tips to avoid the oversize the element’s size & position (shape, text, image): USE FORMULA to make the size and/or position responsive to the size/position of the root container (a.k.a the widget size).
Below is an animated GIF image showing an example of elements with responsive size.
Text with responsive size • KWGT
