Widget • Simple Media Player v2.2.260909
This version is the downloadable version.
I am retiring the previous versions, so any retired versions are no longer available for download.
What’s New
  • Adaptive size for text and album art.:light_bulb:TIPS: don’t resize the widget too small otherwise the text will not be comfortably read
  • Text colors are easier to read
  • Playback controls and track info are easier to read
  • Lyrics scroll navigations are vertically stacked on the right side
Preview
Simple Music Player v2.2.260909
Preset Download
How to Use the KWGT Preset
  1. Download the preset file (the .kwgt file) to your phone
  2. Copy/move the downloaded preset file to the widgets folder, under the installation folder of the Kustom app
  3. Add a new widget on homescreen, choose Kustom Widget and select your preferred size of the widget
  4. Tap on the blank new widget on homescreen to open the KWGT editor, then load the copied/moved preset
  5. Once the preset has been loaded up to KWGT editor, tap the :floppy_disk: button on the top navigation bar to apply the preset
Enjoy the widget!
Now colours everything’s perfect but fornsome reason lyrics do not refresh again. At least on my device. Dunno if doing something wrong
Hi @Excite ,
About the lyrics, it depends on the lrclib.net online service, therefore:
  • The device must be connected to the internet
  • If there’s no available lyrics for the song on lrclib.net then the widget does not update the lyrics
INFO • New version
The latest version is v2.2.260909
Get it from:
Enjoy!
