Hi team,
I am using Nova Launcher with with a 8x6 config.
I’m having trouble with the sizing of the KWGT widget wasting a lot of space in the widget. whats the easiest way to resize to automatically fit
Hi team,
Put the widget with your launcher, resize at your like, then go to Kwgt and put the widget what you want, if you need you can resize the preset in the Layer of the Kwgt widget.
Sorry, what?
Here you have a best explanation by the developer in the Kwgt FAQ on how to resize the widgets
https://help.kustom.rocks/i11-kwgt-faq
When you are in the editor of Kwgt you have a tab with, items,background,Layer, tap in layer and you have in the percentage the option to resize the entire widget here too.
