Widget is not displayed properly after turning off the KWGT notification even when battery is unoptimized
A notification is required for a KWGT widget to work properly, when the battery is optimized. I didn’t want the notification showing up permanently in my notification dash, so I just turned off battery optimisation for KWGT.
I then turned off notifications, but the widget stopped displaying everything in its proper font and arrangment, even when KWGT has unoptimized battery usage. Is there a way to fix this? I can’t really keep a permanent notification like this.
Actually, you don’t need to turn off all notifications. Here is how you do it properly:
Keep the 'Battery O
ptimization’ turned OFF (that was correct, don’t change that!).
Go to Settings → Apps → KWGT → Notifications.
Scroll down to Notification Categories.
Find the one called ‘Kustom Notification’ (or ‘Background Service’) and turn it OFF individually.
Well I had turned off notifications individually from the app.
I did some things like removing the widget and switching widgets, and something worked out somehow and now the widget displays properly.
