Is it possible to have 2 different widgets interacting each other? For example, if I touch one make the other one disappear.
Yes, you cannot remove a widget from screen but you can toggle globals from widget A in widget B, you need to use an URI call. So do this:
- In widget B create a global, name it “hidden”
- In widget B create a visibility formula (just select the visibility properly in the layer options, turn it into a formula), then add
$if(gv(hidden) = 1, NEVER, ALWAYS)$this will hide the layer when hidden is 1 - Now in widget A create a touch action, set the action to “open URI”, in the uri write
kwgt://global/hidden/1to hide your layer orkwgt://global/hidden/0to show, this uri can also be called by other apps like tasker
This requires 3.73
Hope this helps
Thanks, I will try and let you know.
