Wg not updating
I’ve set up a textfield for a note and linked it to a
txt file in the Kustom directory, in a global value.
I can’t get it to update consistantly. I also just tried added some text directly in the note value, before the wg function and that didn’t make it update either. It’s showing an old version of the content in the .txt file.
All other elements (music player, weather) update as expected. It’s just the global value with the wg call giving me issues.
Did not test, but maybe you can use Flows with a Cron trigger to update your global variable value.
I’ll try that, thank you.
