In the Editor it works, the Watch refuses to update (Kustom Action > Force Weather Update) does not change the values.
It used to work previously. (I think KWCH updated recently, the ‘send data’-update).
Watch: Samsung Watch5 Pro
Kustom Action > Force Weather Update sometimes doesn’t work for me either. However, if I synchronize the watchface with the watch again, it usually works again.
What also often doesn’t work for me is the automatic update of the weather data. I have set the update in KWCH to an interval of 30 minutes. But sometimes it doesn’t update for 2-3 hours.
Watch: Watch6 Classic
Phone: Pixel 6 Pro
Same here with automatic updates, last update 2days ago.on mine with 30min updates
I have a suspicion to what it might be connected to. What did you specify as the main location? If I select “Automatic (GPS)” for the main location, it doesn’t work at all.
If I enter a fixed location, it doesn’t work 100% reliably, but it works better. For me it also helpt to re-enter the location manually. Today the weather was always updated every 30 minutes.
I have it off of Automatic, It’s on my neighboring town as I work there.
Set all locations again, after sync
the clock shows a hourglass symbol
, and wont (finish) fetching weather info (yr.no) I think. Watchface works under it tho.
Tried restarting, and yea, same problem (watchface has no weather data now, so last update '5decades ago’
I found a way to have functional updates go through:
Enable WiFi with internet access.
This is problematic as my watch disables WiFi while phone is connected through Bluetooth (unless “An app requires Wi-Fi”)
I can also force WiFi by long pressing the WiFi quick setting… and allowing it to connect (and then going to the homescreen and clicking my ‘update weather manually’ text)
I think I found something that might work out… Developer Options> Turn Off Automatic WiFi seems to keep WiFi online once found.
and the weather updates work while WiFi is connected.
(I just had a bit of a problem getting the phone to connect to WiFi, but it did after a while… and now it stays connected)
