I’ve created my own weather widget and separate clock widget. Both usually work beautifully.
For the last week or so, however, there have been problems.
- Sometimes when waking up the screen, the widget is not showing. It is still there because if I click on that spot on my screen the app opens up. This doesn’t fix the problem, though.
- Sometimes it is not correct. This morning at 8:15, the clock said 2:44. Sometimes the moon icon is showing instead of the sun during the day. Refreshing it doesn’t fix it.
- The only way to get it to work again for both of those problems is to force stop the kwgt app, then restart it. This only works for awhile, then it stops working again.
- I do have it set as a never sleeping app.
- Also, most of the new when I click on the disfunctioning widget, the edit screen never finishes loading.
I love my kwgt widgets! Can you help me get them fully functional again?
