Water Progress Formula?
Would anyone happen to know a formula for water tracking that I can use for a linear progress bar? I track my water through an app, but it logs into the Samsung Health, which I know Kustom has some access to now. Do I need a 3rd party app, or is this doable? Thank you!
I don’t think Kustom has access to the water intake part of Health…
You’d probably need something like Tasker (and maybe its plugin Health Connect)
Also, it is possible that the water intake might be proprietary to Samsung and Samsung doesn’t provide an API to access its data.
CMIIW
:folded_hands::smiling_face:
I just asked Google Gemini AI and here’s the AI Overview:
To get Samsung water intake data into Health Connect, you need to grant Google Fit and other health apps permission in the Health Connect settings to read data from Samsung Health. Since Health Connect acts as a central hub, this setup allows your Samsung water intake data, which is written to Health Connect by Samsung Health, to be read by other apps that access Health Connect, such as Google Fit.
Here’s another one:
Health Connect does support water intake data, but it’s not stored directly in the Health Connect app itself. Instead, you use a third-party app that writes your water intake data to Health Connect, and then you can view it in another connected app like Google Fit. Health Connect acts as a central hub for sharing this data between apps.
