I’ve created a few wallpapers in KLWP, but none of them work when trying to add them as a wallpaper. What shows up on my home screen is a glitched version of what I created. This image shows what it looks like on my home screen.
This looks like a rendering glitch. Try these steps:
Go to KLWP Settings → Advanced settings → Turn OFF Parallel Rendering
If you are using another images for test, try re-saving them as simple JPEGs or optimized PNGs.
Clear the app cache and restart phone.
Thanks, that fixed it!
Great, glad it’s working now.![]()
If turning off Parallel Rendering doesn’t immediately fix it, try setting a standard static wallpaper first, then come back to KLWP and hit Save. Sometimes it needs that ‘handshake’ with the OS to re-request the live wallpaper permissions properly.
