I am using Nova launcher and Redmi 13c phone. The klwp wallpaper does not work on lockscreen. It just shows a gray screen. I tried other live wallpaper apps like (live Anime wallpapers) and those apps work fine. Klwp works fine when it just the livkscreen. Sometimes the wallpaper shows for a split second before gray screen appears
As far as I know, KLWP cannot be used as a lock screen wallpaper.
Also, KLCK presets doesn’t work on Xiaomi phones.
But, I don’t know if it’ll change in future.
I have KLWP running as wallpaper on my lockscreen (Samsung S24 Ultra).
Did you set a specific layer visible “If Locked”?
I’m experiencing something similar. Maybe it has something to do with Android 16?
I’m have a Galaxy Fold 7 and a Flip 7 in my household and both phones will not initially display my wallpaper/background. I’ve been using my own personal presets for years. Nothing has changed.
Both show the walls within the editor. On the Flip 7, if I leave the lockscreen on and just sitting there, the wall will finally appear but only when using an ancient version [3.31b808608…I had other reasons for using this old version. The recent versions will not display the walls either]. The Fold 7 never displays the wall on the Lockscreen [currently, ver. 3.80b519207, I’ve tried many other recent versions both beta and non-beta].
I am using Nova Launcher ver. 8.0.18 (paid/Prime).
Both phones have software as follows:
One UI 8.0
Android version 16
Security patch level: July 1, 2025
ver. 3.80b519207 works fine on the Lockscreen on a friend’s S25 Ultra (One UI 7, Android 15).
Ok, wow, thats very strange, so 3.31 works on the lockscreen 3.80 doesnt, i will investigate this, its quite an issue if i cant reproduce it but i will try on a few devices
