I just installed kwgt, klck, klwp, kwch version 3.76b422013 from the kustom rocks download page. I installed over the previous versions of the apps which were all functioning fine. The apps won’t launch. The splash screen appears and nothing more happens. The widgets won’t load. The lock screen will not work. I have force stopped and cleared cache without fixing the problem…
Samsung galaxy s10 plus. Android 12. Nova-launcher. Not rooted.
Same thing happens to me. Upgraded to latest 3.76b422013 but KLWP will not launch. KWCH works fine.
I’ve cleared data & cache to no avail. I’ve uninstalled and installed it fresh but won’t work.
Pixel 7 Pro, Android 14, rooted, Nova Launcher.
Edit: went back to version 3.76b418415 and that version is working fine.
Interestingly, the problem causing update has been taken down from the download page without comment…
Probably found the issue and reverting back to older working version until it’s solved and reuploaded.
3.76b418415 doesn’t work with 3.76b422013 well (flow, send data) so I hope it’ll be up soon. Been looking forward to this feature.
Today’s update version 3.76b422110 now works again. Kwgt, klck, klwp, and kwch all start up and work as they should…
