Using a formula to set weather icon in base komponent
I’m using the weatherflatsvg preset from the base komponent in kwgt. I want to show the weather icon for the forecast in 3h. I go to the item, globals tab, and set icon to formula. I set the formula to $wf(icon, 0, 3)$. This results in only a placeholder image.
Is this not possible to do, or am I missing something?
First of all, did you create that global variable? Or did it already exist before?
The global variable shown on your screenshot is the one with List type, not Bitmap type. While the element using it is bitmap. So, of you create that global variable, the variable type should be Bitmap instead of List.
Second, the $wf(icon, 0, 3)$ formula is used to display the icon name (text) that is related to the weather forecast, today’s weather forecast in the next 3 hours. In order to show the icon image, you need to define a global variable for each of the possible weather icon names. This variable is a Bitmap type variable, and the variable name should be the same as the icon name indicated by the result of the $wf(icon, 0, 3)$ function.
Third, after you create the global variables for each of the possible weather icon names, on order to select which icon should be used, use this formula for the image filepath:
$gv(wf(icon, 0, 3))$ ➞ the result is the image filepath
I appreciate the help.
The globals are part of the preset (base kwgt komponent WeatherFlatSVG).
I did as you explained. Created a global bitmap for mcloudy. Set the path for the bitmap to kfile://org.kustom.provider/bitmaps/mcloudy.svg as this is the path according to the preset. Set the formula for the icon to $gv(mcloudy)$. This did not work, since as stated this is a preset.
It did give me hope however and after playing around some more I found the steps to unlock the preset and the globals defined within it, et viola, I added the 3h and 6h definitions to the preset’s icon list global and it works!
While the suggestion you provided is correct for other situations but not this one, I do really appreciate you taking the time to answer. It provided motivation to keep trying.
Awesome! For those interested in how this was done:
  1. Open the WeatherFlatSVG komponent after loading it
  2. Unlock by tapping on the lock button from the top right corner
  3. Go to the Globals tab
  4. “Check” the List Icon variable and unlock it with the lock button
  5. “Check” the variable again and edit
Question I have the icon loaded and it is showing how do I move it to where it shows next to my text and not under it?
You really need to look at some basic tutorials. If you’re interested in learning more I highly recommend Brandon Craft’s CraftMath website which has excellent links to his YouTube video tutorials; I also recommend Tored’s Guide to Koding which is really great for people that prefer having a written page in front of them while they work.
Adjusting the position of Items is done with the Item’s Position tab. Depending on what element it is, and the depth of levels, you either adjust the Offset on screen, or the Padding inside another group.
