Updating text field with animations breaks the spacing
Using some forms which adapt to the text height and length. Putting the same as an mask and animating to go down and up… while delaying the update on the Text.
will mess around with the spacing. The update on the Text form is delayed. So the user doesnt see the text changing and instead it will update once the mask moved down… https://discord.com/channels/359763545086230531/499616282077822986/1280036306948194347
Message link inside the kustom discord for visuals.
