Added a Battery Dash Widget. It requires a companion Tasker Project which is also included in a sub folder. If you dont have tasker, some values will not be populated. Also updated Battery Graph Wide Widget. The graph color will change to green if charger was connected during that hour.
Also if you click the graph in dash widget, you can change the intervel. If you click on top half, u can switch to a battery temp graph.
Download from Battery Folder in following Project
