I just updated my KLWP and KWGT apps and I got a notification for Unread Counters Fix.
However, when I tap on the [ FIX NOW ] button to download the Unread Counters app, it appears that there’s no such app to download from Google Play Store.
Yes, I am on the latest. I have had the plug in installed for years, but I was having issues with V1.1 a long time ago so I switched to V1.0, which always worked. I just updated to V1.1 and it’s working again. Thank you.
I’ve had the same issue recently. Battery optimization turns off notifications from kunread. Turn off battery optimization for kunread app and turn notifications back on.
I’ve been scratching my head over the frozen unread counts for a while now. Toggling the ‘Notification Access’ off and back on again in the system settings finally forced it to sync up for me. Definitely feels like an Android system quirk more than a Kustom bug.
I eventually managed to install the Kustom Booster plugin and uninstall the Unread Counter plugin. However, there are still Missing Requirements errors. I even have granted all the required permissions.
