Unable to import a KLWP preset
I created a live wallpaper on your app KLWP and i exported the preset. And i just reset my phone and even i bought the pro key also, but your app just fucked my 1 week work. I was not able to load my preset live wallpaper.
Any one can help me on this?
It’s says failed to load preset
you can try older version for more stability. I think 3.62 is pretty bug free. There’s some omitted feature but if you want to use it with peace of mind you can try those instead. Download it on Downloads | Kustom HQ
Okay, thank you buddy this method working for me.
Whats the issue exactly? I need a bit more context, does the latest version give any error? Can you send me the preset at [email protected]?
