I have set that and nothing coming, could you help ?
$tu(rndimg, 15, “/storage/emulated/0/DCIM/Camera”)$
This is one of the many frequently asked questions.
By searching this forum, here is the solution to the image loading issue on Kustom presets.
https://forum.kustom.rocks/t/cannot-read-image/9435/32?u=baju_santiko
but it’s not changing every 15 minutes , it needs manual action so I assume it’s no more working the way it was designed
I tried to create a test widget which has an Image element, and use tu(rndimg) function to randomly select an image every 5 seconds. It works without any issues.
it’s not working for me, but with the flow it works , thank you for pointing me to that
If I may asked, what phone do you use and which Android version does your phone have?
oppo on android 13 , colour OS but no issue as the flow is working perfectly
