Transparent gradient mask
Hi, I’m trying to make a transparency gradient mask for an object which doesn’t have any background (shape that cover the whole object) like other cases, all are foreground text and shapes.
Is it possible / anyway to achieve the same effect as image shown, and other workaround (komponent xor didn’t work)?
Try them here: demo.komp (68.9 KB)
Original
Expected result (chatgpt generated very bad quality)
