I recently download Nova Launcher and switch to it, but the homescreen is empty, so I try to export my widget from previous launcher and make a new one in nova launcher, but I can’t find my exported widget is when im trying to import it, so does anyone know where the saved widget is? And I also found the exported widget on library, but I couldn’t open it because Im not buy the pro kwgt. It’s my own widget, why do I have to pay for it?
So can anyone can help how do I transfer my widget from previous launcher to nova launcher? Or do I have to make it all over again?
Please use 3.75, press save on the previous launcher widget then add a new one on Nova and load from the backup section, this doesn’t require pro. You need 3.75 because autosave was broken on 3.74.
