Hi guys, the “touch” function on the POCO X6 PRO doesn’t work. I tried to give all possible permissions. I found this link, which seems to solve the problem, but it is no longer accessible
POCO X6 PRO, ANDROID 14, HyperOS
Try to turn off your device’s MIUI Optimization from developer options and see if that helps. You can use the instructions from the link below as a reference.
Now that my device is running HyperOS, KLWP is no longer set as my wallpaper by default when powering on my phone.
Can you change to other wallpapers/live wallpapers just fine? Also, make sure you have the latest version of KLWP or try the latest beta here.
