Apparently i just noticed today that touch is not working. When i touch the widget, it wont open the specific funtion. Also when i put a new widget on screen, i cant touch it to set it up. However i able to run it if the kwgt is running on background app, when i clear or close the app, the touch wont work again.
Im using nova launcher with MIUI 11. KWGT and Nova Launcher are updated to the latest version. Im running on MIUI Global 11.0.5.0 Stable
Okay, i just solved this by enabling permission for KWGT. In the app info, go to other permission then enable the display pop-up windows while running in the background. So far the touch problem has been solved. Thanks.
