TIPS • Color Changing
How to select/change the color of an element?
Preview
TIPS • Color Buttons
Preset Download
Example
How to Open in KLWP
  1. Rename the downloaded preset file (the .zip file): remove the .zip suffix from the filename
  2. Copy/move the renamed preset file to the wallpapers folder, under the installation folder of the KLWP
This is awesome, Baju! Color-changing setups can be a bit tricky for beginners to wrap their heads around, so having a visual guide and a preset to deconstruct is super helpful.
