Im on the latest version of klwp and literally none of the text filters work. Ive tried just about everything and i can’t get them to work does anyone know a fix?
As you can see at the botton i have selected the add filter but it does not work as you can also see
Im on the 3.77b435216 version
First of all, these are 2 different things:
TEXT FILTER
COLOR FILTER
If what you mean is the Color Filter, then it should work. A color filter blends the colors of both the foreground and the background objects, so it depends on the colors of both the foreground and the background objects.
Also, adjusting the opacity of the color also affect the filtered foreground object.
Here’s are some examples of the color filters applied to the same colored text and the same background image.
Yes i meant color filters thank you for the response i didnt know you need to have the image in the same overlap group befote but i figured it out some time ago and its now fixed
