Text field captured using $wg() only shown on editor, not in widget
I have a text field I get using $wg that I can only see in the editor, but not in the actual widget. what could be the problem? although the text in the example is in hebrew, it happens with any text I get, even numbers.
wg command: $wg(“https://www.hebcal.com/converter?cfg=json&g2h=1&date=2026-10-29”, json, .hebrew)$
kwgt version: 3.82
phone: PocoX3 nfc
os: LineageOS 22.2-20261019
Is KWGT battery usage set to Unrestricted on your device? If not, give that a try. Also, clear the KWGT cache and reboot your phone. If the issue still persists, try rolling back to a version older than 3.82 and see if that makes a difference.
wow, it actually worked. clearing the cache and rebooting. thanks!!
