How to animate an element during a screen transition?
Preview
Preset Download
How to Open in KLWP
- Rename the downloaded preset file (the .zip file): remove the `
.zip` suffix from the filename - Copy/move the renamed preset file to the `
wallpapers` folder, under the installation folder of the KLWP - Run the KLWP editor and load the copied/moved preset
