Tasker shortcuts are no longer carried over to KWGT since Tasker update
there was currently a Tasker update, since then KWGT no longer takes over the Tasker shortcut. Old widgets where the shortcut is already saved have no problems, only if you want to set a new shortcut it doesn´t work.
Same problem here.
I ask to tasker developer and this is his answer :
Hi. That's a bug in KWGT that happens only if you are using Samsung's launcher. Can you please contact the KWGT devs about it? Thanks in advance!
So, i have samsung on android 12, one ui 4.1
On the laucher, i can select tasker shorcut. It's work fine. In KWGT, i get blank return.
Checking this in the meanwhile if you are running Kustom 3.72 you can use an URI rather than a shortcut
Sorry, but i don't understand your solution.
I don't see URI. (I check, i have 3.72, in french localisation, may be that why i don't find)
Having the same problem. Also on Samsung.
Can you please explain what you mean by using an URI instead? How would I do that?
Would be nice if this issue can be fixed in a future update.
I'm having this issue too. Is there a fix on the way?
Hi all. Is there a work around of fix for this yet? I have the same problem - S21 Ultra Android 13 - One UI 5.1
Still working on this, shortcut can be used as an alternative in the meanwhile, will fix on 3.75
Hi Frank can you elaborate further at all? Use shortcut?
Got it to work by opening URL link
tasker://assistantactions?task=ToggleTorch
Precisely what i meant, thats the way, you can also use it in Flows or in touch actions, i am in parallel investigating while shortcut doesn’t work in One UI
