Some KWGT widgets not scaling properly
Certain KWGT widgets will scale properly up until they reach a certain size, and then 100 on the scale is way oversized. This can be seen here.
The best way to create or rescale a widget is first put the widget with your launcher in the screen and resize at your like, then put the kwgt and resize it with the scale in Kwgt.
The problem is if you try to use the scale to resize to 560 in a container that is 480, the wiget are going to be oversized, because Kwgt control the size of the preset, not the container in your screen.
Yes, but this is in my KWGT pack. I have to in some way solve or workaround this issue so that it's not a hassle for my users.
