Smart Launcher not loading presets on widget
Since Nova has been having a lot of problems lately, I decided to try Smart Launcher and bought the Pro version. However, when I add a widget and try to load a preset (whether from a backup or one from the collection), nothing happens—the widget remains empty. Does anyone have a solution for this?
I don’t know what steps you’ve already tried, but you can also try resizing the widget or forcing a save in KWGT that usually makes it appear.
And make sure battery optimization is disabled for both KWGT and Smart Launcher.
