I wanted to share a preset that displays the widget size and resizes the text depending on the widget size.
I used lv and some if logic
I tried to make it as few moving parts as would allow. I hope it helps people visualize the space taken on their screen. Oh, by the way, you can tap the notch to make the text even larger.
Here is a video of it in action, along with a static size widget. Unfortunately the static size looks terrible in small widgets.
–WINSEVN
Dynamic_Resizer_with_Notch.kwgt (98.7 KB)
