Sharing unfinished project
sheet.klwp (561.5 KB)
Hey people
I started to build a wall some months ago, had a plan to upload to the play store. When I felt close enough to do the next step, I found out, that google make full name and address public, so I abandoned the project. Since that I just let it be on my phone unpolished, it was okay for me. Then few weeks ago, out of nothing, it’s started to behave very strangely. All the blurs won’t show, there r missing elements, random align issues etc. (Even in the builder) I didn’t do anything significant on the phone, been using a15 since long time, so I don’t know what’s going on.
Anyway, as I mentioned above, because of that nonsense of google, I’m not gonna put more time in it. Therefore I share it here, if somebody see some potential in it. I know I have strange taste, maybe 1 in a 1000 could like, but if u r that 1, I’m glad.
Some bugs r definitely still there, plus incomplete parts, also as I’ve learned some things from the beginning, now I know that plenty of code could be shorten, and things can be done with way less elements, and all that…
U can set height globally, as well as radius of roundness, dark/light theme, date format, etc. Make sure to touch everything to find all features :D. Also, it can work with any backround. Just create a klwp_bg folder to the root, and drop your image. (this last function also stopped working for me, hope it’s on my end only)
So here it is.
(In case you know a fix for me, it’d be still appreciated though, as without blur it looks a bit boring:D)
Ok I’m just going to say it, I’m not as amazing to create something as this mainly bc i don’t have spare time but also not advanced user. but this is awesome and minimalistic 3-page setup. although i may not be the best person in terms of giving advice but one thing i got over years by having my phone factory reset at any random time and experiencing countless dataloss i got used to using tasker and macrodroid to use it with kustom’s br function. it makes backing up my kustom functions and data through tasker’s builtin backup function so don’t have to lose my customization. it surely taskes aways lot of time by getting my setup right but it’s worth it for me to make it not lose all data. :smile:
Does it work, as it shoud? All blurs? What about the wallpaper?
Would u mind to share a screenshot, I used 4 images and only one accent color while building/testing. Just curious how it shows with other walls and accent colors.
(I’m not sure what u mean with the second part)
