Hey
I think I need a way to set a Text Global’s value to be a formula.
I think, when I tap a button, it’s overwriting a formula with a fixed value.
Any help appreciated.
I have 3 sections of screen that show different content (Apps, Games, Music).
Each has a button with a touch action that both shows/hides it’s content, and also hides the other sections content.
I want the Music section to show automatically on a trigger from a Tasker value. That bit works, but for the first time only. When I tap a button it no longer responds to the Tasker variable.
Text Globals:
tMusic, returns a true/false string. $br(tasker, tMusic)$
vMusic, $if(tc(up, gv(tMusic))=“TRUE”, 1, 0)$
vApps, holds a 1/0 value. Default to 0
vGames, holds a 1/0 value. Default to 0
Touch action for “Apps” button, as example:
Toggle global switch, vApps, text: $if(gv(vApps)=1, 0, 1)$
Toggle global switch, vGames, text: 0
Toggle global switch, vMusic, text: 0
