When you load a preset the first time KWGT changes the scale in order to fit the item inside the widget, this is currently the default behavior, if you set scale to 100 by default the widget might not fit the area of the one on screen
I don't know if it sets the scale by using the wrong "thing"/"variable" or what I should call it. If its from the launcher, KWGT or the preset. But the scale on 4x4 should have been about 133 and not 288.
It seems the scale depends on the size the widget has, I dont mean the 4x4, but how big the widget is set. But the scale does not folliw the size I make, it seems the be exponentially. At a certain size, the preset begins to be bigger than the widget size and the sides gets cut off.
