Semi blur in klck
Hii guys can someone teach me how to achieve this semi blur like this
If you want to try it in Kustom:
​Create a Shape (Rectangle).
​Set the Color to fully transparent (remove the main color).
​Go to FX → Shadow, set the shadow color to match your theme, and crank up the Blur and Amount.
​But the best way is to just blur the image in Photoshop or any photo editor before loading it into Kustom. It will look much cleaner and more natural.
Hi i try it but still nothing
In the FX tab of your shape, make sure to set Mask to Blurred Background and adjust the Blur value.
@Baju_Santiko posted this. Just add the Shadow @MaxP mentioned to ease the edges.
