Save option not working KWGT
I am currently making a widget. When I select save to save my work, it works. But then a few hours later, when I decide to do some more work, it shows me the previous change! The widget on the home screen is untouched; until I press save again and my most recent work disappeares. Can you fix this?
Hi John, you need the pro version to save and reload your widgets. The free version allow to save your work and use it in your screen, but not reload it to rework in it.
What I mean is that when you open Advanced editor the floppy disk icon in the top right corner. Thanks anyway!
