Its shows the text inside the klwp app but not when i save it and go to the main screen but not images inside or outside klwp.
Samsung s23 ultra android 6.1 klwp 3.62.
hmm… maybe upgrade to latest version of klwp might solve the issue. latest version for klwp is 3.76, if you can’t update it through google play get it from here KLWP APK Download | Kustom HQ
Done that but it didn’t work i downgraded to 3.53 and everything is fine many thanks though for your time .
Please DO NOT use old versions, can you provide the RSS formula you are using so i can check whats going on?
But it works fine on 3.75 i tried hard as i could on 3.76 builds it wasnt just the rss it was music player, colours everything but the rss links i use
mmajunkie.usatoday.com/feed
http://www.gizchina.com/feed/
Thanks. You said “3.53”, so you are using 3.53 or 3.75?
So nothing works on 3.76? Can you share the preset as well?
Im using 3.75 and i use Ginos sets and kylde sets his evolution set on his page didnt work with rss text or colour matching.
Same problem for me on KWGT 3.76 Pro when phone updated to A14
Same RSS url or different? Can you provide it?
