Replace or delete Yahoo weather provider
The Yahoo weather API hasn’t worked in applications for a long time, so it would be worth removing it. Or replacing it with the weather.com provider.
Yahoo shouldnt be visible in the options, if it is its a bug or you have a very old version, unfortunately weather.com doesnt provide any good free API
I’m actually still seeing the Yahoo provider even on the latest build.
I am using the latest version downloaded from Play (with purchased Pro license).
Hi everyone,
I do not know whether these weather services are good or not and 100% free or not, perhaps someone could gives any review on them:
This has been fixed, thanks, wont show up
Thanks!! Will review
