How to rename preset (or space)? Instead of Widget 32, to rename into something usable
You will have to export the widget to give it a proper name and all the additional details.
Stll unclear how to rename preset. Have tried to rename the file kwgt but internally (Kustom panel) it still has the old name. When export it again the kwgt file saved with the old name.
Also description. How to edit it?
Plz, help …
Yes, when you export a preset again, the app will suggest the same name. You should be able to change that name to your preferred one. So the steps are:
- Open an empty widget
- Load the preset you want to rename
- Open the side menu and select Export Preset
- Change the Title field
- Select Export
- Open the side menu again and select Load Preset
- Load the preset you just exported
We cannot rename an existing preset, we can only re-export an existing preset under a new name. After that, we can delete the old one if we want to.
