Right now, I have to pick between using a stable version, or getting features early. If the Kustom beta would be released separately, I could have the stable version powering my home screen, and test new features as they come out.
to do that tit would require massive rebuild of classes of all kustom and it would introduce location access bugs related to storage so it will probably not be the case but it should be done I see why you are saying for different separate app for beta since they have unfound bugs, meanwhile i hope it does get released as separate app but chances are low. though using older device should be good until then meh LOL. or just rename package through the revanced manager for beta apk though it is not recommended.
