To make story short: I love Kustom apps. But since moving from the M62 to a S22+, I’ve had nothing but problems wit it. Constant crashes, slowdowns, heating, battery drain, all of it.
Today, however, I decided to try KLWP again, against my best judgement, and ended up buying a pro license to import a few presets to test.
Well… Not only is the app extremely glitchy, I can’t even edit some of the imports because it keeps freezing. Took me less than five minutes from buying to uninstalling it, and for such, I’d like to get a refund, but since I bought the license in-app, I can’t seem to find an option for such
Send an email to [email protected]. They should be able to help you with that refund.
