Question about wf functions
Im trying to confirm if I get this right…
We have the function:
wf(type, day, hours)
So when I type for example the code:
wf(rainc, 0)
Ill get the possibility of raining for today, the whole day. So, basically its the “daily” prediction.
If I type the code:
wf(rainc, 0, 0)
Ill get the possibility of raining pulled from the hourly forecast, so basically this is possibility of raining for the present hour.
Are my assumptions correct?
Well NOW is a fine time to ask, after releasing your komponent :rofl: . . . I’m just kidding. In answer to your question, yes, but there are some exceptions. I’ve found that some ‘forecasts’ for right now, the current time, don’t seem to work and I need to use wi instead of wf.
lol yeah well it was just an icon anyway.
And yeah I noticed too that sometimes the providers dont fully respect the wf - wi distinction. For example, Im convinced accuweather’s wi wind direction seems to always be 0, while using wf seems to be more accurate for the present time although it “should” be a forecast, not the real state.
That’s strange. I always get a degree result using $wi(wdir)$ with AccuWeather on my weather screen and I don’t think I’ve ever seen 0.
Hear you, perhaps I need to check more times and observe the results, maybe it just happened to be 0 during the times I checked.
Thanks for the feedback. Im just trying to figure out by trial and error which parameters for “now” behave well with wi functions and which ones with wf - although I understand that typically, for current weather data I need to use wi, not wf
Edit to add:.hmmmm, maybe if wind speed is 0, then there is no actual direction, so it goes null - 0 anyway? Ill check
