I found a bug, when using a rectangle as a clipping mask inside of a group. No matter which direction you move it, the crop area will always be the same, it sticks. It’s a problem I’ve experienced before, but today it turned out to be quite annoying. clipping masks have always worked “weirdly”.
Did you move the mask Shape or did you move the group that contain the mask?
the mask, because its effect only applies within the group it is in
